91 L-DRIVE IMPELLER
DAJUICE
HELLO. I HAVE A 91 MAXUM WITH A FORCE 120 HP L-DRIVE. JUST FOUND OUT THE IMPELLER SHAFT IS NOT TURNING AND THAT IS WHY THE OVERHEAT ALARM COMES ON. HAS ANYONE REPLACED AN IMPELLER SHAFT ON A L-DRIVE? HOW COMPLICATED IS IT? ANY HELP WOULD BE GREATLY APPRECIATED. THANK YOU.
RRitt
Re: 91 L-DRIVE IMPELLER
the impeller is mounted directly on drive shaft. it is sandwiched between the bottom and top half of the motor. there are seven or eight bolts that hold gearcase onto engine. After you take them out, the gearcase just falls off ... or wiggles off. <br /><br />It is an extremely easy job that should take 2-4 hours for a first timer. add 1-2 hours for every seized bolt. routinely maintained engine = no seized bolts. not so routinely maintained engine means the great unknown.<br /><br />if you do have a frozen bolt, do not try to force it out by overpowering it. nothing will make a simple job difficult as quickly as a snapped off stainless steel bolt. use a combination of propane heat, pb-blaster, impact driver, and patience. a little bit out, a little bit in, a little bit further out, and a little bit further in. tiny little baby steps.<br /><br />if frozen bolts are a real issue, then check anode. if salt water engine then clean guide holes of residue and coat bolts with silicone gasket sealer during asembly. if salt water engine, it also never hurts to run a high quality tap down the threads and make sure that they are clean.
RRitt
oh ... using new bolts is always a good idea too. if memory serves me then you need 6@ 5/16-18 x3.25"hex head and 1@ 5/16-18 x 1" socket head for the gear housing. if you get a complete water pump kit with housing then it should include new bolts for pump.<br /><br />www.boltdepot.com will have the odd length SS bolts in stock.
