'91 Force 120 hp water pump housing
greenlantern04
I am changing the impeller and thermostat on my 1991 force 120 hp L-drive. I started with the impeller, got down to the housing and noticed the metal cup was worn and oblong at the hole where the shaft comes through. It also has a lip on top which wore an oblong groove in the housing. I'm wondering if this will affect anything or if i can just grind off the lip and call it good. I've found the cup but if i need to replace the housing as well does anyone know the part number for just the housing and not the whole kit?
oswald
Re: '91 Force 120 hp water pump housing
greenlantern04
the number of the housing only is F694060-2(body,water pump)
you can see the parts manual in boats.net
good luck
oswald
