Just bought my first boat. Its a 1991 Stratos 274 f/s 17.5ft all original factory rigged with a 90hp Johnson V4 w/ VRO, 20" pitch Raker SS prop. Currently, EVERYTHING on the boat works (knocking on wood). Took out on its maiden voyage yesterday and she ran great.
I know a lot about car motors, but now boat motors------
My question(s)??? The boat will be run in saltwater here in Perdio Key FL for the next 3 months then I will be going back home to dallas and it will then be a freshwater boat.
-What should I expect the top speed to be around and at what rpm's?
-What should I do/check/replace to make sure she keep running good.About the only thing I know to do is flush it with ear muffs after I take it out and thats about it.
-How long does it need to run with the muffs on?
-Do i need to run up the rpm's at all while flushing. I have read on hear to let the motor heat up to open up the t-stat, but just running it at idle the temp gauge never moves and the water coming out of the tell-tale always seems cool.
-Do i turn the water hose on full blast or turn it down?
-Is there anything that i should go ahead and replace as a precaution?
-Anything to the hull or trailer (steel-painted). I hosed both off and wipe the hull and gunwale with 1 part water/1 part vinegar.
-How does it need to sit to justify running the engine out of gas? Until the winter, it will be in the left in water and run almost every weekend and put back on the trailer during the week.
-When in the water overnight, to i need to lift the engine out of the water and flush or leave in the water and just fluch when it gets put back on the trailer sunday evenings.
Any and all help/suggestions will be appreciated. I am very particular about maintaining things, causing me to be very paranoid at all times thinging I made be screwing something up, and this feeling is worse b/c this is my first boat. Been on and around boats alot, but they weren't mine so i wasn't responisble for keeping them up.
This forum is great, I have been reading on it not stop since I decided to get a boat trying to educate myself.
I appreciate everyones help!!!
Kyle
Kyle
