91 200 yamaha outboard flywheel cannot be turned manuelly
Motor wont't start and flywheel cannot be turned manuellty does that mean the motor is locked up or could there be something else causing it?
D
DJ
Guest
Re: 91 200 yamaha outboard flywheel cannot be turned manuelly
RRG,<br /><br />Try this.<br /><br />Remove the spark plugs, then try it.<br /><br />Next, remove the lower unit and try it. If neither of those two work, your powerhead is locked up, for some reason.
