Mike Caspari
- May 8, 2005
- 21
I had switchbox problems before on one motor and replaced both switchboxes, motor runs fine now. My other motor is beginning to lose fire on 2,4,6 in the low rpm range. I put one of the old switchboxes on and it worked for a couple of days, then I had to put the other old switchbox on it works again for now.<br /><br />Stator ohms good, trigger ohms good. <br />I noticed that some time my spark seemed to return when I wiggled the key in the keyswitch.<br />The ignition switches are exposed to the elements, could this be my problem? The stop circuit voltage does get routed through the ignition switch right? Can this affect one switchbox and leave the other alone?
