90's tohats 3.5 wont start arrrggghhhh
dkonrai
friend drops off a tohatsu 3.5 its a 3.5b.
compression 60 pounds (seems low)
i have spark (jumps only about 3/16 inch)
i have fuel as the plugs are wet.
installed a drill on the fw to spin the motor. doesnt matter if its wot or choked slow . i cannot get the motor to fire. i even squirted some starting fluid to see if it would at least pop. nothing at all. i get a periodic burp out the exhaust. new gas, i get good flow at the carb. carb is clean. plug new.
even though it has low compression it should fire? albeit it will rough. i sprayed fuel in the carb too, nothing at all.
im thinking its gotta be the lower oil crank case seal? im out of options.
thanks
dino
pvanv
If you have spark, but a wet plug, you are probably flooded. Adding ether and/or gas to the intake will make it worse. Try a fresh plug, WOT, and no choke, until the extra fuel is out of the crankcase.
