last fall the water pump went out, so this week I put a new water pump kit in the lower unit and when I get it all back together it runs great and it's pissing water as it's supposed to but when the handle is in the neutral detent location the prop is in reverse, when you shift the handle to reverse, no change. when I shift the handle to the forward location, the prop is in neutral.... its like everything got shifted a little bit one way and there isn't enough handle movement to get it to go forward.... this is the first time the motor has ever been apart or had any problems since new in aprox. 1993 its a j25telets
did I put something back together incorrectly???? any help would be much appreciated
