workinoffsho
- Aug 30, 2002
- 12
I have a 81 mod 90 hp Johnson V-4 I recently too it into the shop for a tune up. The problem I am having and the mechanics are not able to figure out is this. The motor will start and run at idle both in the water as well as with the ears. After launching the boat and letting it warm up a few minutes I back off of the dock and when I give it the throttle to take off it floods out. I have to restart and lift the fast idle where it will only run around 3000 rpm then after a few seconds it will rev to 5000 rpm. I then will try to throttle up and again it will flood out. I will have to repeat the procedure three times before it decides it wants to go. I noticed this after the second time taking the boat out after the tune up. It will do the same thing after I have anchored for a while and have to idle out of a shallow area. It all points to some type of flooding to me but I can't figure out how to correct the problem. Any help you can give will be greatly appreciated.
