Re: 90hp tohatsu warning buzzer
Not to steal this thread from Matt, but this brings up an interesting point. I had installed a new impeller back in march, and everything has been fine, but a month ago or so, I accidentally started the motor when it was up out of the water, and turned it off instantly after I noticed this. It had idled for no more that 1-2 seconds without water. Since then, every now and then, I will get a warning beep when shifting from N to F. The sound is the same as if you where to try and start the motor while in gear, and only lasts a second or so. A visual on the tell tale shows the same constant stream as before. Any ideas? Is it possible that it is not the water pressure alarm, but rather that the little detent sensor in the control box is sticking (the one that tells the motor it is in gear before start-up)? This may be the same problem Matt is haveing.
