90hp Mercury 4stroke
74century
Recently bought an aluminum boat with a 4stroke merc,the boat has not had its (first) 50hr service. Hour meter reads 35hrs. What does the service consist of? Is this something I can do or does it need to go to a dealer? Also can it go before 50hrs or slightly over the hours, thinking about using it this year then taking it to the dealer in the fall. Thanks
GA_Boater
How old is the motor?
I would change the impeller for peace of mind if it's more that 2 years old or if the boat/motor has been sitting with no use. You can change it in the driveway.
GA_Boater
3-4 years old, the impeller should be changed. A year of sitting unused isn't good for the rubber and it can become brittle/hardened causing it to break off vanes.
Faztbullet
As posted needs impeller changed, all oils and filters and grease fittings hit a lick with grease gun.Make sure you grease drive shaft splines when impeller is changed.Just a note to drain engine oil before pulling lower unit as some of the early models will self change when you remove unit !!!!!
