Re: 90hp Merc - trouble with startup
enrichen the idle needles 1/8 to 1/4 turn open As long as you have new or good plugs in it. Bad fuel in the summer heat and humidity. Your fuel starts to loose octain 2 wks after you pump it. The motor will boil the fuel out of the carbs after you shut it off this time of the yr so you may have to squeeze the primer bulb to fill the bowls up again.<br />corm
<br />oops I see your from up north so the heat thing is less of a problem.
