Fishin4fun
- Mar 3, 2004
- 66
Ok, I finally got the motor installed. I have a few questions though,<br /><br />1. If I turn the motor, fairly quickly from one side to the other, it will stall. I have checked all my connections and everything is good and tight. I ran her on the lake WOT and no problem as long as I dont turn quick, at idle if I turn quick (docking maneuvors) it will stall.<br /><br />2. Are there any adaptors to convert the mid-80's control boxes to the 79 model that I have with the plug on the side of the motor? I would like to buy a newer contol box and replace my throttle cables as the box/cables now are a little stiff, also I would like a control box that locks into neutral, which mine does not.<br /><br />3. The motor is equipped with power tilt/trim and it works great, is there a way to install a trim indicator?<br /><br />4. Would running 16oz in 5 gallons pose any problems for my motor?<br /><br />Thanks,<br />Ed
