90HP Force - Missing Choke And Linkage
Kh988
Hi guys i just bought a pontoon boat with a 90hp Force , its missing the choke solenoid and linkage would one you have a picture of the whole setup on the motor , i can find new solenoids online but no luck with the linkage Thanks in advance
GA_Boater
They used 2 different systems on the 90hp.
Ones an actual choke the other is an enrichment system????
Need to know year, model??
Pics help too.
Once the mods see this they'll kill it and you'll get no response.
No we don't. As long as the hijack post lends itself to moving to a new thread, we do. Some posts just don't make sense to move to a new thread and in that case the thread is closed.
Kh988 Your new thread and welcome aboard.
BoostedTimmy
I can get you an actual picture if you'd like, but here's an internet picture that shows it all. That long rod going diagonal behind the fuel lines is the only linkage besides the rod between all the carbs. When you engage the choke it energizes that solenoid which pulls the rod down.
jerryjerry05
Boosted, are you and KH988 working together?
Need to see the actual pic and close up.
The short rod? I might have??
