Hi,
I believe I have an early 90’s force 90HP outboard motor, Serial number OEO61952. I am at a loss with what is wrong with the starting system. I tested the continuity across the solenoid and solinoid to starter and it all rang out. If I hook the battery straight to the starter it turns. But when I turn the key the starter won’t turn. I am able to measure 12 V getting to the solenoid when the key is in the on position. Trim works and I can hear the choke engaging when I push the key in. The key did turn the starter about a month ago and then I changed the steering cable and it has not worked since. What else can I be checking to see what my issue is?
