I have a 1992 Evinrude 90HP. The model number is E90TLEND. The problem is that the engine will only idle if the Engine cover is on. Once you try to take off in the water it dies out. You can avoid the problem if you take the cover off. It runs fine after that but you have to leave the cover off. Any ideas what the problem is? I think it may been a blown gasket. Please Help.
