hi i am new here, also to boating.<br />i have a small boat with a 90hp yamaha, yesterday was the first day i took it out.<br />shortly after starting it the buzzer went off it was a continous sound. so i turned off the engine waited for a second then turned it back on and it no longer sounded.<br />i drove up the lake, and as i applied the gas the engine picked up speed but then stuttered, and did not go any faster. so i eased off on the gas and just cruised around at a low speed, but it did it at exactly the same amount of rpm's<br />i was on the lake about 20 minutes.<br />and as i was putting the boat back on the trailer i realised i had not primed the engine with the primer bulb, and i hadn't taken off the air valve on the gas tank.<br />would this be a cause of the problem for the loss of power? any thoughts or oppinions would be appreciated.<br />thanks<br />daniel.
