90A Battery Isolator
Menace2Authority
I have a 1979 165 hp Mercruiser in-line 6 cyl motor. Currently there is only 1 battery in the boat. I bought a second deep cycle battery and a 90Amp Battery Isolator. What I WANT to do is run the current electronics and ignition off the battery that is currently in the boat. I have a 1 amp solar panel charger to keep the battery charged while I'm away. I want to run a stereo with 2 speakers, 2 10" Sub woofers powered by an 1100 Watt amp. Will the 90A Isolator be enough to keep the batteries charged off the alternator that's in the boat? My worry is that the stereo will draw too much power from the secondary battery and that the Isolator will not allow enough of a charge to go to the primary battery. Other than a small fish finder and the power trim I won't be running much off the primary battery as I don't use the boat at night time. The bilge only has to be run after a heavy rain so it doesn't kick on throughout my boating adventures.
I'm not 100% sure how the isolators work and how much (if any) it will cut back the charge going to the batteries as it directs the charge from the single alternator wire to two batteries.
There was also a 120A isolator but it was considerably more money..... more than twice the price.
Thanks,
Rob.
BaileysBoat
Re: 90A Battery Isolator
Isolator rating will be determined by alternator output plus 10%. Going to loose voltage across a diode style isolator. I would go with a dual battery switch having alternator protection.
Boatist
What is the current voltage output of your alternator?
Is it a 1 wire alternator or a 3 wire alternator?
If it is a 3 wire alternator then you will loose no voltage to the batteries if wired correctly.
As stated before size of the alternator output is what determins what size battery isolator you need.
If it a 1979 then the alternator is likely 65 amps or less as that about as big as supplied back then so 90 amp isolator is fine.
Also back in 1979 I think most alternator were 3 wire.
If it is 3 wire you can wire where you will loose no voltage to the batteries.
Menace2Authority
So if it's a 3 wire Alternator is there somewhere where I can get a wiring diagram so that I know how to wire in the batteries so that I don't lose any voltage? I will cruise the net but will more than likely get a response quicker here than I will come across via google as my luck completely sucks seeking out information on the net :(
Rob
Boatist
So far I have not been able to get the picture to post but the instruction are below.
The bottom line is you probably do not have to do anything as it is probably already wired the right way. When you wire your isolator the output wire from the altenator, the large usually red wire that usually goes to the post the main battery connects to which is useally on the starter or starter solenoid. This large wire usually 10 guage red will need to be cut. The side from the alternator goes to your isolator common post. The side that goes to the battery will go to isolator output 1.
Your second battery goes to isolator output 2.
The second and 3rd wire to the alternator normally do not have to change at all.
One will go to the ingition switch and is the smaller of the two wires. The other is larger about 14 guage usually red or orange is the sense line and it goes as near to the battery as possible. It will normally go to the same post on the starter as the other.
The only time you would loose the .7 volts is if it was connected to the common post on the isolator or the alternator output. As long as the voltage sense line is connect on the battery side of the isolator you will not loose the .7 volts.
This is only true with a 3 wire alternator. It is different with a 1 wire alternator or an outboard. I do not know why people constantly say you will loose .7 volts to the battery.
Do It Yourself Hot Rod Kustom Website
Electrical - Wiring up the Alternator
1976 Camaro three wire alternator
One of best inventions in the early 70s, is the three wire alternator. The voltage regulator is built into the alternator. This makes it very easy to wire up and it also has the added benefit that the voltage regulator is no longer a mechanical device but now semiconductor based - no adjustments!
There is a common misconception about alternators and the term one wire alternator is often thrown about. Most people mistakenly identify a 3 wire alternator as a one wire alternator (I know, I was one of those). A one wire alternator was only used for limited applications and has distinct disadvantages. The 3 wire alternator is a proven design and has been used for the past 30 years starting in the late 60s, early 70s. Here's a website that discusses the advantages of a 3 wire alternator over a one wire: Advantages of a 3 wire alternator
3 wires are actually used plus chassis ground
There are 3 wires needed to run it and the case provides the path to chassis ground Even though there are 3 wires, it is very easy to wire up. Here's a desciption of the wires:
Battery positive (Bat+)
connect to starter +12V battery wire
use 10 ga wire (thick)
Screw on terminal on the back of the alternator
Voltage sensing line
connect to the Bat+ close to the firewall
Senses and adjusts the +12V were it is needed
use 14 ga wire (thinner)
Pin 1 of the push in connector on the alternator
Ignition On input
When the ignition switch is turned on, power from the ignition switch turns on the alternator
Pin 2 of the push in connector on the alternator
use 18 ga wire
In the above pictures, you can see a black wire that is connected to the alternator mounting bracket. I ran an extra ground wire from the firewall directly to the alternator's mounting bracket just cause I'm paranoid about bad grounds. Normally the engine has a ground strap between it and the firewall which provides an excellent ground. I've painted all my parts and want to make it 100 percent sure. Most likely it is not needed as millions of cars work perfectly fine without it.
Between the starter and the battery is a short piece of wire about 1" long that is a smaller gauge than the main wire. It is a fusible link. The idea is that if there is a catastrophic short in the wiring harness, the fusible link will burn up before the rest of the wiring harness. It operates on the same principle as a fuse.
