I am new to PWC, but I've worked on plenty of other engins.<br /><br />Here is the deal.<br />Purchased unit last month. Unit ran fine for 1 hour, then died and would not start. There was no water in the engine compartment. Engine showed no signs of being hot. It started just fine when I got it home. Exact thing happentd the next time I took it out.<br /><br />Next problem. Being curious I took the carb apart for a goog cleaning. I thought I put all the needles back to their original positions, but it smokes much worse now. Does anyone have the factory carb setup. I need to know which needel does what, and the recommended position after a rebuild. I should then be able to dial it in after that.<br /><br />Thanks for any help!!!!!!
