Have a 2004 90 Tohatsu LPDI that started to give me some trouble. I am waiting now to get it in to the shop but thought I would post here to see if anyone knows what the problem is.
Starts and runs great but occasionally while running at speed under load all 3 tach lights will blink on at the same time then off with no alarm noise and then immediately the rpm's fall. The engine does not stall but will not act normally until you drop back into neutral. Once the engine is brought back in to neutral you can accelerate again and it will be normal for 300yards or so then the problem repeats. It will do this a few times then run completely normally for the next 15 miles.
Any ideas or what the 3 lights blinking on and off means?
