I have owned the boat for a few years and have been told that its a good time to change the impeller in the lower unit. I changed the impeller and just in time. When i put the lower unit back on everything went fine. The only problem i have is that i cant get the shift lever in the boat to move. I seperated the lower and upper unit and even with the lower unit off the shift control does not move. I did not have the boat in forward when i seperated the units the first time and i see that everybody says that it should be in forward. Did i mess something up or am i doing something incorrect?
