I have a 1990 merc 100hp that I just bought. Took it home and started it up and i'm not getting any water out of the "pee hose." Figured it was an old destroyed water pump so I got a new pump kit and replaced everything. I'm still not getting anything through the cooling system.
I took the lower unit back off and put a hose directly where the pump pushes water up and it seems like it's not getting past the mid section. Not really sure if the water tube is out of place near the powerhead or what. If I blow air up that same tube I can feel some of it coming out the pee hole, but not a lot.
Do I have to remove the midsection to get to the top of the water tube? or is there an easier way?
