PWH1
- Jan 11, 2010
- 78
I have had my new to me boat out twice this year and it has run very well. However, I felt like I was not getting all the 90 horse had to offer in regards to performance. I am getting a WOT of approx 33 MPH with max RPM of around 4600 (moderate load - prop 14x17),
This evening, I pulled the carb cover and pushed the throttle all the forward to what would be WOT. As I look into the carbs, I can see that the butterflys (carb plates) are only opening about 1/4 of the way. I have provided a few pictures of the carb and the plate that engages the carbs to open the butterflys. They are all taken with the throttle in WOT position.
Looking for advice...
Do I need to adjust the throttle cable so that it pushes the carb plates further open? If so, how do I go about doing this? Is this whats refered to as 'link and sync?' (fyi - the cables were recently replaced prior to my purchase of the boat - so they are new)
Lastly, when i removed the carb cover, I found this thumb screw in the bottom of the cover. I cannot find any obvious area where this would have come from and I doubt it came out of the carbs.
Thanks - PWH
Thanks - PWH
