'90 Johnson 150GT Overheating!
spin-a-bait
I bought this boat about 4 months ago since then I have had nothing but trouble with it.I have had the carbs rebuilt,compression check,new fuel lines,VRO pump checked,new sparkplugs,new head gasket,waterpump,I have spent $1,600 since I have had this boat.The problem is that the motor keeps overheating or at least the overheating horn is saying that.The motor runs fine but all of a sudden it will overheat and the heat sensor will bring the motor back to 2500rpm just like it is supposed to.The last guy that worked on it found that the head gasket that was put on the boat before I got it was made with silicone and it was blown,which is not supposed to be there.Also the reason it was overheating was the silicone got stuck in the cooling ports.But the guy that worked on it said that was all fixed,But since I have got it back from him I drove 50miles before any trouble.But when it overheats all you have to do is turn the motor off then start it right back up and it will run great but then It will do it again.Would someone please help!
