barbender55
- Mar 9, 2004
- 23
Hi. Situation is this. 1992 90 hp 2 stroke outboard is blowing fuses. I replace the fuse and motor trim works and motor fires up. After a few minutes under power trim will go down but not up. Then nothing. When I stop fuse is blown. Replace fuse everything works but when under power for awhile it goes again. I cleaned posts on battery. Also wiring in throttle seems fine. Any suggestions? Thanks.
