90 HP Weight
dozerII
Hi eveyone visiting from the dark side as you say. My 75 merc crapped out and I a, looking at a 93 Johnson 90 hp with T/T. What can you tell me about this motor and what does it weight. My last boat had an 82 115 evenrude and I loved it.
Thanks
Glen
GeneH
Re: 90 HP Weight
Weight on that should be about 314 lbs. I just bought one on a 1993 Sunbird with trailer for $1100. Weather here has been so poor I haven't gotten very far with checking everything out. I heard it run and it had 115 115 125 125 compression so I thought that was ok. These are durable engines and, given reasonable care, last a long time.
ezeke
Re: 90 HP Weight
ML model weighs 288 lbs (131 kg)
TL model weighs 301 lbs (136,5 kg
TX and WTL models weighs 306 lbs (139 kg)
WTX model weighs 311 lbs (141,1 kg)
TTL model weighs 314 lbs (142,4 kg)
dozerII
Re: 90 HP Weight
:) Thanks for the info guys, I will get some more info from the dealer then decide on this motor.
Glen
dozerII
Re: 90 HP Weight
Thanks again for the info. I ordered the motor today, It is being complelty rebuilt top to bottom and I should have it mid february.:D
