My 90 HP, 2 stroke, 1999 outboard does not always turn over. It seems like if I disconnect the battery and reconnect it, it will then turn over but not every time. It does spark when I connect the positive post (also intermittently). It seems like when it does not spark is when it will then turn over but not 100% sure about that. I checked my battery and it did check out "weak". Is this a battery issue or could it be something else? Should it spark upon connection of the positive post or is this indicating an issue - not sure if it is a capacitor discharging or not. Does not seem so as it will spark many times in a row.
