1998 90hp johnson v4...Ran my boat yesterday all day with no problems. today i got back in the water and 1/2 hour in I notice at WOT it started to lose power. while trolling after that engine shut off. I turned it back on and head to shore at full throttle and it started to lose power again , this time it would do it on and off. I would go slow then fast then slow again with out touching throttle. Finally I just headed to ramp at really low speed. I got no signs of misfire, spark is good and so is compression. I changed plugs while on the water today. When I got home I ran it on hose and when engine started to shut off I pumped bulb and it idle right back up so staring to think its a fuel feed issue and hope it's something not very expensive. I will be changing fuel lines and bulb in the morning but wanted to hear some other thoughts.
