Have a 1990 90hp Johnson and need to replace water pump. I have the shop manual and did the following: 1. Removed prop 2. Put in reverse and moved pin in the shift lever inside engine. Pushed shift lever toward engine. 3. Removed trim tab and three more bolts at rear of gearcase. 4. Removed 4 bolts on the sides of the gearcase.<br />Gearcase drops down about an inch and I can rock it side to side and up and down but something is holding the gearcase front to the engine. I think it's the shift rod. Don't really understand how to release it. Any help is appreciated. Thanks
