90 hp force wiring diagram
shaggyyqq
I have recently taken off my 1991 90 HP force and placed it on a sawhorse. I would like to be able to run the motor connected to a battery but not sure how. Does anyone have any idea or a wiring diagram for the force? It came out of a 1991 Bayliner Capri if that helps. :confused:
steelespike
Re: 90 hp force wiring diagram
There is a color code at: www.brokeboats.com<br /> If you can identify some colors you may be able to hook up.Dont attempt to runn without muffs.
steelespike
Lonewolf I see your still looking for your 1&2<br />cylinder solution.<br />I dont know the answer but have you tried the library for a manual. They must have a trouble shooting section to help pinpoint problem areas.
Kip
Hi, I have the original owners manual from my 1990<br />bayliner with 90 horse Force. It has a wiring diagram in it.
