jerb_54729
Thread starter- Joined
- Jul 18, 2002
- 13
My 1988 90 hp evinrude vro will start fine, but will spit and sputter and stall if I try to give it gas. If I push the choke in it helps a little, but still runs rough. When I finally coax it up to planing speed, it will run great. If I run at WOT for 10 minutes or so, I can pull the throttle back to neutral and get it back on plane with no problems/pull water skiiers, etc.<br />However, if I shut it off for 10 minutes and restart it does the same thing.<br />I have replaced the spark plugs, fuel line/primer bulb, cleaned pickup, checked fuel tank vent.<br />Where do I go from here?
