If you had two identical boats, one with a 90 and the other with a 115: you'd find the two engines would launch out of the hole similarly. After 150 feet, you will see the 115 will slowly start to walk away from the 90. Eventually it will leave it in the dust. 115's have different block porting (flow more air) and larger-throated carbs than the 90. (flows more air and fuel) The 115 has higher performance heads to boot. (heads are different part numbers.) When the 90 is screaming at wide open throttle, you can pull back on the 115 throttle. When the two keep pace with each other, you'll save fuel on the 115.) The 115 will run one higher pitch prop than the 90.
