maxum-mama
- Jul 22, 2007
- 15
this would be the reluctant boat mechanic husband of maxum mama. (you can call me rbmech). after having put many more hrs and untold riches into this pathetic excuse for a motor/lower unit i have come to the end....or so i thought, only to realize that the driveshaft on a '93 force 120 has 13 splines wherin the lower unit has 15 splines!...sigh.
the easiest fix i can see is if i can find a collar that is a 15/13 split, otherwise it looks as if i will need to switch over the crank...if the 90 fits into the 93...!
suggestions and or input? thanks.
rbmech
rbmech
