wvmedic
- Jun 3, 2008
- 508
To give some background, I have a 1984 90 ETLN and have been having an overheat issue since I bought it. I have put two new impellers, a thermostat and took the head off checked the water ports and cylinders for damage. I found no damage to the cylinders on the tear down so I put new gaskets on and retested on the water, I still had an overheat issue at anything above half throttle. Idle temps and up to half throttle was around 150 degrees Fahrenheit, anything above half throttle temps would get up to 210 degrees.
So I took the exhaust cover off to inspect the water ports and found the skirt of the top piston damaged, could this damage be the cause of my overheat problem?
Also what dose it look like I need to do as far as a rebuild, or is it worth doing? I already have about $1,000.00 in this motor.
Thanks Jeff.
Thanks Jeff.
