90 ELPTO compression readings
dandreye
Hello All,
What compression is typically found on a brand-new 90 ELPTO and what *absolute* reading requires overhaul? I cannot see any figures in my service & repair manual. Other posts on this topic tell me that anything above 100 PSI and 5-10% between cylinders is OK, however my mechanic is saying the official figure is 10 Atmospheres (147 PSI) and overhaul is required if the reading is below 6 Atmospheres (88 PSI).
A reference to the service & repair manual page or a screenshot with the figures in question would be very much appreciated.
Many thanks in advance,
Dmitriy
JB
Re: 90 ELPTO compression readings
Believe what you read here, Dmitriy. Compression guages, conditions and technique vary too much to set arbitrary specs.
dandreye
Hello JB -
I do indeed. My compression reading is 103 PSI, which tells me we are OK. Just wanted to know where I am with it within the maker's margins.
Many thanks,
Dmitriy
mikeneal
I have a 1999 90 HP ELPO that Ic bought well used about a year ago and it ~110 psi in all cylinders.
Hello JB -
I am indeed. My compression reading is 103 PSI, which tells me we are OK. Just wanted to know where I am with it within the maker's margins.
Many thanks,
Dmitriy
dandreye
Mikeneal - thanks for your reply.
Any more feedback from newer 90 ELPTO owners? I'm still looking for a reading on a brand-new or nearly new outboard of this model.
Thanks in advance,
Dmitriy
