90 DT2, idle, thermostat
The RealRookie
Ok, didnt realize this was water cooled. Is there a thermostat on these things? And where is the idle adjustment?<br /><br />Took off the prop but i cant get the pin out to inspect the impellar. I can lift the cover a little and it looks ok, but im not getting much water out the little hole on the top of the shaft. Im getting little fast spurts. This is why im asking about the thermostat. I have a pdf file i found online but it doesnt show any thermostat anywhere.<br /><br />I also need to get the idle down a little. I bought the motor and tightened up the throttle linkage nut on top of the carb because the throttle was very loose and now the idle is pretty high. Same pdf file doesnt show idle adjustment screws, well.... it might show them but it doesnt say this or that one is for idle.<br /><br />Thanks for any help!
