'90 60VRO JOHNSON WARNING HORN
Gage
THE WARNING HORN ON MY '90 60VRO JOHNSON COMES ON IN A CONSTANT BUZZ WHEN THE KEY IS TURNED TO THE "ON" POSITION AND WHEN THE ENGINE IS RUNNING. WHEN I PULLED THE BOAT OUT OF STORAGE AND RAN IT TO MY DOCK LAST WEEK, I DIDN'T HAVE ANY PROBLEMS. I WENT TO TAKE IT OUT THE NEXT DAY AND THE WARNING HORN CAME OUT AS SOON AS I TURNED THE KEY. THE OIL TANK IS FULL. ANY SUGGESTIONS?
D
DJ
Guest
Re: '90 60VRO JOHNSON WARNING HORN
Do you have a good stream of water coming out of the "tell tale" on the starboard side of the engine?<br /><br />Can you hold your hand on the top cylinder when the engine is warmed up?
DIRTPOORE96
HI GAGE, I WOULD MAKE SURE ALL OF YOUR BATTERY CONNECTIONS ARE CLEAN & TIGHT. YOUR HAVING A GROUND PROBLEM WITH THE SWITCH OR HORN. PULL HORN OUT & CLEAN THE STAB ENDS ALSO. THIS COULD BE THE PROBLEM. :)
