I just bought a bassboat with the motor and first thing I did was change the lower unit oil and water pump impeller. It was pumping water when I test drove it, but now with the new impeller, it will not pump any. Took the thermostats out (Just for now to eliminate them). With the lower unit off, I put a hose to the water tube to the engine and water flows through fine,but the pump will not pump it through. Did not use new seals on anything becouse the shop told me I would not need them. Going to buy a new pump housing tomorrow, but cannot figure it out. Please Help!!!
