J90PLSOA Johnson 2 stroke. Having problems at lower rpm. It runs rough at idle up to about half way up to WOT. I change the plugs, filter, water separator, check to make sure it's getting a spark at plugs and cleaned the carbs. Oh and for some reason it seems to run better when the balance tube on the starboard side that goes to the main bearing is unconnected. My rpm gauge does not work so i can't give you a specific number when it runs better. Any ideas. Much appreciated.
