pontoon chief
- Aug 9, 2004
- 116
Have a 2001 tiller model 4stroke 9.9 that when started runs fine.After several seconds (30) it starts to run rough,and will not let you advance the throttle.When you do so it just sputters and pops out the carb.I cleaned out tye carb ,(it was not dirty),changed the carb with a new one,no help.I checked the coils with metter and have the same omh readings as a new out of the box coil.I contacted tech support and explained what I had done and was told that the only thing lefy was the CDI box,and that was preventing the motor from advancing the RPMs.Quess what,they were wrong.There is no differance.<br />Compression is good in both cylinters,tested fuel pump and have 6,5 pounds pressure.I am at a loss.Any help from the wisemen would be appreicated.<br />Thank you people for your time and efforts on these boards.........
