9.9 Mercury Stuck "priming valve"
jjtorg
I have a 9.9 Merc. Outboard, the kind that primes the motor rather than really choking it. there seems to be a mechanical stoppage in that when I pull the knob out, the plastic lever cant depress the little blue fuel primer (on the right hand side as I look at the engine from "pull position"). I am tempted to take off the 4 screws that hold down the plate surrounding this button and see if there is some blockage that keeps it from depressing.What am I likely to see under there ? is there any history of ongoing problems with these priming systems ? any advice would be appreciated...<br /><br />John T
ODDD1
Re: 9.9 Mercury Stuck "priming valve"
John, chances are you will be pulling off the carb....to acess the 7/16" brass plug under the blue primer...that has the output check ball and spring under it....it is this check valve or the primer outlet on the carb flange that is plugged......
jjtorg
Thanks for your information. It sounds likely that the little spring and ball may be jammed with something. I will try it.<br /><br />Thanks again. :)
