9.9 merc. outboard
manny-c
I have a 9.9 merc with a busted shaft, lenght is 30.5" long I have another merc. short shaft,is there a way to get the short shaft on to the long shafe merc..thanks
mnydvr
Re: 9.9 merc. outboard
well tis is an easy one!you grab one end and have a friend grab the other end and PUUULLLL! till its the right length,then just so you can laugh about it,as soon as you have the right length,let your end go!! this job is best done on the end of a dock,just make sure your not at the end!! and don't forget to check for straightness when your DONE:p
James R
Your best bet is to look for a replacement on Ebay. The short shaft will not fit up to the long shaft casing and connect.
