I have a 1986 Mercury 9.9 2-stroke that I had not started up in at least two years. Couldn't remember if I ran the gas out of the carb when I last shut it down.
Anyway, I hooked it up to a relatively fresh tank of gas this afternoon and started it up. Nothing unusual at first, but then I noticed some foamy, greyish, oil droplets in the can of water I was running the engine in. After I stopped the motor, this time running the carb dry, I emptied the can and when I looked at the motor, there was the same greyish brown, oiley foam apparently coming from the prop exhaust and around the prop itself.
I removed the lower end oil drain plug and the oil looks fine, not milky at all and no water showing.
So can someone tell me what this foam is? I'm planning on getting back into fishing this next year and want to get my gear ready ahead of time.
Thanks!!!
Thanks!!!
