Re: 9.9 Mariner Tweeks?
Hi Bubba,<br />Sorry, all you can do is trade it for a 15HP.<br />Your motor is 12.8 cu inches. The 15 is a 16<br />cu inch motor, so it is a whole different block. The OMC motors are both 13.2 cu inch<br />blocks, so parts interchange.OMC also revs the 15 another 750 RPMs to get the HP. Where as the Mariner's both run at 6000 max RPM. If<br />you need more power,try a smaller prop.Every inch in pitch will change the RPM 150 RPMs.<br />I don't know what boat it's on, but a stingray mounted on the cavitation plate would give you more tail lift. To plane faster and make the boat run flater. One other thing, most 8-25 HP Mercs and Mariners<br />I see mounted on boats are mounted to low.<br />The cavitation plate should be no more than 1/2 inch below the bottom of the boat.If yours is low add a wood shim to the top of the transom to raise the motor within specs.<br />Then BOLT the motor to the boat sealing the bolt holes, so their are no leaks. Even the smaller motors can slide off in a hard turn.<br /><br />...have fun...corm
