Hello all. I just picked up a 94 Johnson 9.9 and it needs a little more work than I had hoped. First I have no controls with it so trying to figure out what is compatible.. The motor starts easy but can't get it to idle (and not sure where idle position even is ?). It's leaking gas in between pump and carb which I will fix first. I also noticed water leaking at the gasket on a housing at the rear of the motor. Found electric connector inside not hooked to anything. Not even sure where to begin, is there a parts diagram that can get me started available somewhere? Any help would be greatly appreciated. Thanks!!
