Timberwolf17044
- Mar 20, 2011
- 53
I recently purchased what I assumed was a 1979 Johnson 9.9 Long Shaft. The seller indicated to me that he could not get it to run and I bought it as is for $50.00. Once home I began with a brief inspection and an attempt to start the motor. This particular motor has an electric start. I found that with a bit of fuel squirted into the carb I could get it to fire. I disassembled the carburetor and soaked it overnight in cleaner. Once reinstalled it would fire better but still wouldn't run. Further investigation found a faulty fuel pump. With a new fuel pump and some tweaking I finally got the motor to purr like a kitten while in a barrel in my garage. Forward and reverse seemed fine, water pump seemed fine. Fast forward to today, the first chance I've had to actually put it on the boat and test it on the water. FYI I tested it on a river with rather strong current on a 12 ft fiberglass boat designed for a short shaft motor. I modified the transom to raise the motor to the proper height. So anyhow, I started up the river, going slow at first feeling the motor out all seemed well. After a couple minutes and feeling more comfortable I opened it up further, finally to wide open the boat sailed along quite smoothly almost to a plane. I slowed back down a bit and then began slowly opening it back up only this time the motor picked up rpm but no go. So there is my dilemma, It feels like the transmission is slipping and yet I don't think there is a transmission to speak of is there? Now to add a bit more to this mystery I will add some additional information.
Model: LD-12A
Serial: J2757042
{taken from the tag that is riveted to the transom mount}
J10SELGSE
E5236247
{taken off the freeze plug}
Any guesses as to what the actual size and year this motor might be? Attached are a couple of pictures as well. Thank you in advance for those who can help.
http://www.ajpeachey.com/mark/botamotorsmall.jpg
http://www.ajpeachey.com/mark/botamotorsmall2.jpg
Model: LD-12A
Serial: J2757042
J10SELGSE
E5236247
