9.9 Force (1994) Fuel Pump question
DocBob
I have a 1994 Force 9.9 (model 225.581996) that hasn't been started in years... I am just running through every thing and have a question on the fuel pump.
I pulled the fuel line coming out of the fuel pump off. When I pump the primer bulb on the fuel line I get good flow, but when I pull the start handle & turn over the motor, no gas is pumped out...should there be??? Or does the pump need to be rebuilt?
sweezy722
Re: 9.9 Force (1994) Fuel Pump question
You should probably get a little pulse with every rotation from pulling the rope. After that long you are due a fuel pump rebuild and a good carb cleaning and possible rebuild.
DocBob
Thanks Sweezy...I was afraid someone was going to say that!!!
