pontoon chief
- Aug 9, 2004
- 116
have a 94,9.9 evinrude that cuts out at wide open throttle.<br />When on the water it will run great for 15-20 seconds at wide open throttle than it dies out completely.<br />At times you can pull the choke out and it will catch and regain RPM's only to do the same thing again,but it will only catch sometimes,and it will only catch at the low RPM range just before it stalls.<br />Have rebuilt the carb,replaced the fuel pump,and even went as far as changing the CDI box thinking it might have something to do with the problem.So far nothing helped.<br />Any idea's?,as I have had this thing apart so many times I should have used zippers to put it together the last three times...
