Re: 9.8 Tohatsu to 15 - Whats the truth?
Check your manual. If the bore and stroke are identical. then the engine displacement is the same. IF that is the case, then the engine can usually be modified with 15HP parts to convert it. Evinrude/Johnson, amongst others, is famous for restricting down their 15HPs to 9.9 with smaller carbs and different reed stops.
