Have a 1971 9.8 Merc, was running fine and then decides it won't start. It used to start on 1st pull and then nothing, thinking it might have been flooded I put it in gear at WOT and pulled it (was tied up to dock) and it finally started. However as I reduced throttle it would cut out abruptly before I could get revs low enough to put in neutral.
It continued to do this so I thought perhaps idle jets were plugged (even though I have gas filter on line). So I cleaned carb as best I could at the cottage and put it back together and still the same.
Could this just be a carb that is still plugged, or what else could it be? I was getting spark and gas - I was wondering if it could have anything to do with the timing advance and spark not timed well at lower revs. Wires looked good as far as I could tell. It just seems odd how quickly it shuts down when I reduce throttle. Cuts out hard at about 3/4 throttle, but was running good just an hour before!
Appreciate any thoughts.
