Hi, I've got a 9.8 Merc from what I can tell its a 1983. Ser#7200128. It pumps water but not a steady stream in neutral if I put it in gear and its pretty steady with decent flow.I checked the impeller it's like new. Blew out all the lines and this motor doesn't have a thermostat. I left the motor running for 10 mins in a Barrel in gear it didnt overheat but the water coming out of the tell tale is very hot right from start up I can barely hold my hand under it for a second or two. I'm assuming this is not normal operation for these mercs? I know my Johnson with a thermostat pisses Luke warm water at best and is a steady flow weather it's in neutral or hin gear. Any ideas out there? Thanks
